Recently I have been getting BSODS due to the Clock_Watchdog_Timeout error. It only happens in Bf1 and Overwatch. It happens maybe one a week and it has happened in BF1 twice in the past 2 days with some other crashing in that game. With a quick lookup of this error it seems like it could be a faulty core in my CPU but I dont know how true that may be. Really need to find out a way to fix this as I dont feel like dishing out for another processor.
Note: the CPU is overclocked to 4.5ghz @1.325v
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/723570-bsod-issue/
That error typically means your CPU is deadlocked and nonresponsive. Try downgrading your overclock/disabling it. If that still doesn't work, some further diagnostics will need to be done.
Tech enthusiast and CS Student
https://linustechtips.com/topic/723570-bsod-issue/#findComment-9207231
1 minute ago, airdeano said:
do you get the same result with the OC removed?
havent tried removing the oc but i will soon
https://linustechtips.com/topic/723570-bsod-issue/#findComment-9207235
Your OC isn't very stable at those games. Sometimes a seemingly stable OC will stubbornly fail at specific software... Try upping the voltage / lowering the clock
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/723570-bsod-issue/#findComment-9207251
21 hours ago, airdeano said:
that'd be the first step. if you have to RMA the CPU and it does not act up at stock, the RMA will be denied as they will not overclock the CPU to find the BSOD.
Running an OCCT stress test on the CPU resulted in another BSOD after about a minute, dropping the OC down to 4.3 let the stress test go on for 15+ minutes with no crashes and max temp being around 57c. Now to try BF1 I guess. Just hoping it wont tank my CSGO framerate but I dont think it would since my system is more than capable of running CSGO.
https://linustechtips.com/topic/723570-bsod-issue/#findComment-9211419
Don't worry about CSGO hehe, your CPU can run it at the high 200s without even overclocking the thing :P
~ Specs bellow ~
https://linustechtips.com/topic/723570-bsod-issue/#findComment-9221348
