JavaScript Problem
Solved by Mooshe,
document.getElementsByTagName() does not return an HTMLElement, but rather an array of elements. You would need to iterate through the list to modify the style of each element:
for(h in document.getElementsByTagName("header")) {
h.style.top = ...;
if you just want to edit one specific element, I would recommend providing an ID attribute to that element to select it.
