Hey guys, are there any RGB fans that are controlled via software? Ive got a gigabyte z170x-gaming 7 board. dont know if that makes a difference or not. im wanting to have rgb fans in the front panel of my Thermaltake View 27. thanks!
https://linustechtips.com/topic/721761-rgb-fans/
8 minutes ago, bdn813 said:
Sorry actually just looked at my case and they both connect with a splitter attached to a molex cable
ok this might be a really dumb question, but will a 3pin fan make it to where the fan speeds up and slows down as needed or is it at a constant RPM from start up?
https://linustechtips.com/topic/721761-rgb-fans/#findComment-9187782
Not 100% sure but I think the 4th pin is there so you are able to change the speeds of the fans from bios or other programs. If they are 3 or connected to molex then they just run at a constant speed but don't quote me on it
https://linustechtips.com/topic/721761-rgb-fans/#findComment-9187792
