First time building pc, turned it on and bios came up. I have 0 idea what to do now... I have windows on a usb but do I need to install these cds I got with my pc first? Got 2, Motherboard and graphics card. Also I don't have a cd drive so I'm not sure how I would get those on anyways..
https://linustechtips.com/topic/721741-need-some-help/
Ok so heres what you do
first go to the boot order and set your usb as the first drive then re boot. Then install windows. Next you can install the drivers on the disk or you can go to the sites on another pc and find the newest drivers. Once all those are finished look in the bios for a button to update the bios (connect ethernet if you havent yet). Some mobos can have them updated that way. If not Then look on the mobos page on the manufactures site and download the updated bios to flash at your lesure.
https://linustechtips.com/topic/721741-need-some-help/#findComment-9187601
i7 4930k \ Asus P9X79 LE \ Corsair H100i \ 16 GB DDR3 G.SKILL Ripjaw \ Asus Strix R9 380x 4GB \ Crucial 500 GB Sata III SSD \ Thermaltake TR2 RX 850W \ Corsair Crystal 460 Black \ Razer Naga Molten edition \ Razer Black Widow Ultimate \ Klipsch Promedia 2.1 speakers \ Hyper X Cloud Alpha \
i5 6600k\ Asus Z170-A \ Corsair H100i v2 \ 16 GB DDR4 G.SKILL Ripjaw \ Asus GTX 1060 6GB 4GB \ SanDisk 480 GB Sata III SSD \ Seasonic G Series550W \ DIYPC Skyline 06 black/green \ Razer Naga Epic \ Razer Black Widow Chroma \ Logitech 2.1 Speakers \ Logitech G430 \
https://linustechtips.com/topic/721741-need-some-help/#findComment-9187848
Whoa hold on there cowboy, even manufacturer's suggest you only flash a new bios if there is something wrong with your current version. Telling someone who doesn't know how to install windows to flash their board is a good way for him to end up with a paperweight. Flashing is not to be taken so lightly.
https://linustechtips.com/topic/721741-need-some-help/#findComment-9187849
