Falling particles help
Go to solution Solved by dialgarocksful,
Anyways, I found the answer. Turns out, I also need to set the Y-position in the Update method
protected override void Update(GameTime gameTime)
	for (arrayCtr = 0; arrayCtr < snowRect.Length; arrayCtr++)
		randY[arrayCtr]++;
        if (snowRect[arrayCtr].Y > 770)
			randX[arrayCtr] = rnd.Next(0, 1366);
			randY[arrayCtr] = -5;
        snowRect[arrayCtr] = new Rectangle(randX[arrayCtr], randY[arrayCtr], 10, 10);
    base.Update(gameTime);
Anyways, without the use of engines I'm trying to create a snow effect in XNA. I'm definitely sure I'm doing something wrong since I'm targeting for a 100-count array and it only produces 10 (including updates). Here's my file and looking for some help in displaying all 100 in timed manner:
public class Game1 : Game
        GraphicsDeviceManager graphics;
        SpriteBatch spriteBatch;
        Texture2D snowTex;
        Rectangle[] snowRect;
        int[] randX;
        int posY, ctr, arrayCtr;
        Random rnd;
        public Game1()
            graphics = new GraphicsDeviceManager(this);
            Content.RootDirectory = "Content";
            graphics.PreferredBackBufferHeight = 768;
            graphics.PreferredBackBufferWidth = 1366;
            IsMouseVisible = true;
        protected override void Initialize()
            snowRect = new Rectangle[100];
            randX = new int[100];
            ctr = 0;
            arrayCtr = 0;
            rnd = new Random();
            posY = -5;
            for (int q = 0; q < snowRect.Length; q++)
                randX[q] = rnd.Next(0, 1366);
            base.Initialize();
        protected override void LoadContent()
            spriteBatch = new SpriteBatch(GraphicsDevice);
            snowTex = Content.Load<Texture2D>(@"Snow");
        protected override void UnloadContent()
            if (GamePad.GetState(PlayerIndex.One).Buttons.Back == ButtonState.Pressed || Keyboard.GetState().IsKeyDown(Keys.Escape))
                Exit();
            posY++;
            ctr++;
            for (arrayCtr = 0; arrayCtr < 100;)
                if (ctr == 120) // TRIGGERS A NEW SET OF SNOW PARTICLES EVERY 2 SECONDS
                    ctr = 0;
                    for (int q = 0; q < 10; q++)
                        randX[q] = rnd.Next(0, 1366); // RANDOMIZES NEW RANDOM X POSITIONS
                arrayCtr += 10;
            for (int q = 0; q < 100; q++)
                snowRect[q] = new Rectangle(randX[q], posY, 10, 10);
                if (snowRect[q].Y > 770) //IF SNOW[Q] GOES PAST GRAPHICS WIDTH
                    posY = -5;
        protected override void Draw(GameTime gameTime)
            GraphicsDevice.Clear(Color.CornflowerBlue);
            spriteBatch.Begin();
            for (int x = 0; x < 100;)
                for (int y = 0; y < 10; y++)
                    spriteBatch.Draw(snowTex, snowRect[y], Color.White);
                x += 10;
            spriteBatch.End();
            base.Draw(gameTime);
https://linustechtips.com/topic/721727-falling-particles-help/
  x += 10;
You're calling draw on the first 10 items in the array 10 times each.
1474412270.2748842
https://linustechtips.com/topic/721727-falling-particles-help/#findComment-9187480
1 minute ago, fizzlesticks said:
Use a single loop that goes from 0 to 100. You're breaking things up into batches of 10 but doing the same thing to every element anyway.
it gave me a single line of 100 textures. Now, how do I fix this particles into batches of 10 or <insert number here> per instance?
https://linustechtips.com/topic/721727-falling-particles-help/#findComment-9187492
2 minutes ago, SCHISCHKA said:
hlsl programming
i cant do that yet. I'm only limited to 2D games, so most likely the particles the player will be seeing is just a 4x4 pixel snow image that spawns from top to bottom in batches of 10
https://linustechtips.com/topic/721727-falling-particles-help/#findComment-9187534
		randY[arrayCtr]++;
https://linustechtips.com/topic/721727-falling-particles-help/#findComment-9187645
