I'm pretty new with building PCs
I just wanted to know if it's better to have 2 intakes (front and rear) with 1 exhaust (top) or front and side intake with rear exhaust? or if anybody has a better fan setup suggestions; maybe 2 exhaust and 1 intake? idk. I'd be happy to try it out. Thanks
https://linustechtips.com/topic/721505-help-with-fan-setup/
It depends on your specs.
https://linustechtips.com/topic/721505-help-with-fan-setup/#findComment-9184950
33 minutes ago, SCHISCHKA said:
1 or 2 front intake, 1 exhaust. anything more gives diminishing returns. side intake is for a overclocked GPU if your gpu is running hot
Alright. I'll try out 2 front intakes with 1 rear exhaust, thanks for the help
https://linustechtips.com/topic/721505-help-with-fan-setup/#findComment-9185156
15 hours ago, SCHISCHKA said:
... side intake is for a overclocked GPU if your gpu is running hot
Or rather exhaust if OP would be using open-air cooler style on GPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/721505-help-with-fan-setup/#findComment-9188373
