As my PC's front panel Audio jack does not work any more so i decided to buy and Sound Card which i did but now it does not pick my headphones or Woofer (speakers) at a same time.
It does work separately.
The thing i want to achieve is that:
  • I want to get sound from Headset + Woofer system ( Speakers ) at the same time
  • If i switch off my woofer system ( speakers ), i get sound from Headset.
Any Idea how can i do that?
I'll update this thread with Pictures of sound card ports and In windows sound settings in a while.
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
https://linustechtips.com/topic/721297-sound-card-headset/
Whats the problem with your rear audio I/O ? Soundcards dont neccesarrily provide much benefit over onboard audio unless you are an audiophile and have money to buy expensive cards to get a little different sound with minimal improvement or you mobo doesnt have enough slots for 5.1-7.1 audio.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/721297-sound-card-headset/#findComment-9182291
Just now, Thony said:
Whats the problem with your back audio I/O ? Soundcards dont neccesarrily provide much benefit over onboard audio unless you are an audiophile...
Wait what?
its possible with back audio i/o?
Some guy told me that i need a sound card in order to get audio from Headset + speaker system at the same time.
I have an ASUS P5K-Premium Motherboard.
Here are its Back Audio I/O
https://linustechtips.com/topic/721297-sound-card-headset/#findComment-9182302
1 minute ago, Waqas409 said:
Wait what?
Why do I miss the most important part :(
Well forget what I said then.
I have no clue if its possible but getting a sound card is surely the simploest way. You know there are some tech wizards who will make anything work, the process can be lengthy and more expensive though.
This might be total out of my ass idea but wouldnt "audio splitter" help in your situation ?
https://linustechtips.com/topic/721297-sound-card-headset/#findComment-9182314
ah okey.
I have no idea about audio splitter.
I'll wait for some tech guru to respond to my post, maybe it will be solved.
Thanks tho :)
https://linustechtips.com/topic/721297-sound-card-headset/#findComment-9182328
