960 Pro or Evo?
Go to solution Solved by Gonio,
Doubt the reliability would be a issue for you in general. But the PRO is more reliable and also has more warranty.
For the performance I don't think your mentioned workloads justify the better performance and pricetag over the normal Evo. But if you somehow have big and long transfers from like 5-10 minutes of a single file often, the Pro has significant better steady state performance. But that does not seem to fit your mentioned workloads.
My current 256gb 940 Pro keeps getting backed up on me, and I'm at the point where I need to do a storage upgrade. I have a fancy new Asus X99 board and figured I would go for a M.2 NVME drive, but I can't figure out it was worth it for me to stick with a Pro series or downgrade to an EVO drive. I will be getting either a 512gb Pro or a 500GB/1TB Evo and will pair it with a new HDD for bulk data. I am pro user and use my system for some gaming and media creation in the form of modeling/rendering for local architects, and will be getting into some light Adobe Premier work related to that.
Main Rig "Rocinante" - Ryzen 9 5900X, EVGA FTW3 RTX 3080 Ultra Gaming, 32GB 3600MHz DDR4
https://linustechtips.com/topic/720816-960-pro-or-evo/
You wont notice any performance increase or reliability in the pro drives for a standard workload. The Evo should work fine, and be cheaper.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/720816-960-pro-or-evo/#findComment-9176868
3 minutes ago, shermantanker said:
My current 256gb 940 Pro keeps getting backed up on me, and I'm at the point where I need to do a storage upgrade. I have a fancy new Asus X99 board and figured I would go for a M.2 NVME drive, but I can't figure out it was worth it for me to stick with a Pro series or downgrade to an EVO drive. I will be getting either a 512gb Pro or a 500GB/1TB Evo and will pair it with a new HDD for bulk data. I am a prosumer, and do some gaming and freelance media creation in the form of 3d modeling and rendering for local architects. Thanks!
I'd go for the 1TB EVO. You're not gonna be doing intensive read and write tasks anyway so the speeds shouldn't matter that much.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/720816-960-pro-or-evo/#findComment-9176876
How big of a difference is the reliability between the two? I know the numbers have changed a lot since they moved off SATA, but I haven't kept up much.
https://linustechtips.com/topic/720816-960-pro-or-evo/#findComment-9176909
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/720816-960-pro-or-evo/#findComment-9177099
Thanks! Looks like I'll go for the EVO then, and there are a few floating around Ebay for a good chunk cheaper then the $500 amazon wants for the little bugger.
https://linustechtips.com/topic/720816-960-pro-or-evo/#findComment-9177179
