Hi,
I always wanted to build a very good gaming PC for myself, and until today I've never built an entire PC on my own, just bought them ready-to-use and changed some parts.
So, I'm planning to do this sometime in the next 2-3 months, and I came up with my ideal build (I think).
https://pcpartpicker.com/list/Q6fFYr
I was wondering if you guys can give me feedbacks for this selection, or changing suggestions (to lower the price, improve performance, look and feel, anything).
Just some observations:
  • I'm considering adding one more graphic card in the future to use 2-way SLI.
  • The reason for me choosing the current graphics card is the support for Asus aura sync.
  • I'm planning to add some RGB stripes in the future.
  • Also, I want to change the RAM in the future for a RGB one with higher frequency and support for Asus aura sync.
  • The keyboard and mouse does not work with Asus aura sync, but based on reviews I've choosen them over the Asus ones.
  • At some point in the future I may change the case for one that looks like this one and that has USB Type-C on front.
Also, I did not decided myself over the monitor yet. So if you can advice me between these models (considering price over features) it will be great:
  • Asus PG348Q 34-Inch Widescreen IPS LED Curved Monitor
  • Acer Predator XR342CKBMIJPPHZ Size 34
  • Acer Predator Z35 35 inch Wide screen Curved Monitor
  • LG 34UC88 (W) 34 (34) Computer Monitor QHD
  • LG 34UC98 LCD Monitor
Thank you very much :)
https://linustechtips.com/topic/720770-feedback-for-build-plan/
3 minutes ago, deXxterlab97 said:
Newegg seems to be selling the newer grey variant, i'd say he should be fine. Would get a bitfenix fury or B2 instead though.
https://linustechtips.com/topic/720770-feedback-for-build-plan/#findComment-9176437
But outlet, bestbuy and jet are selling the green label. Besides for same price he could get a GQ too
https://linustechtips.com/topic/720770-feedback-for-build-plan/#findComment-9176454
2 minutes ago, deXxterlab97 said:
And the spec list below is green on newegg too. This is confusing
Thanks for the suggestion about changing to EVGA.
And about the prices and the variants, I'm going to buy it from Amazon in Germany, so there's a little increase in the price, but no problem with that :)
https://www.amazon.de/dp/B00ALK1TPE/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1X7WAGM09IIL5&coliid=I1F7HWPAKU5AUM&psc=1
https://www.amazon.de/EVGA-210-GQ-0750-V2-750W-SuperNOVA-Netzteil/dp/B017NW4NXW/ref=sr_1_2?ie=UTF8&qid=1484062676&sr=8-2&keywords=EVGA+750W
Thanks,
https://linustechtips.com/topic/720770-feedback-for-build-plan/#findComment-9176485
