Ok, So I am getting a i5 4670 non K, because I do not want to overclock and I need a good motherboard that has the following: usb 3 headers, ATX(I just don't care for micro ATX), and I need it to be able to have a Coolermaster Hyper 212 Evo( I just want some better cooling) with dual channel G skill ram without it being in the way.  Here is the two that I found so far and that I think will work but am not sure, so I need your opinions and if you have something better that would be great.
Gigabyte GA-H87-D3H: http://www.newegg.com/Product/Product.aspx?Item=13-128-603&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
MSI H87-G43: http://www.newegg.com/Product/Product.aspx?Item=13-130-697&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
CPU: Intel i5 4670(non K) Cooler: Hyper 212 Evo Motherboard: Gigabyte GA-H87-D3H Ram: Corsair Vengeance 8Gb (2x4Gb) @1600Mhz HDD: WD Caviar Blue 1TB GPU: Gigabyte GTX 770 OC WF3 ~1293Mhz max boost clock~ PSU: Corsair RM 750 Case: Corsair 300R Windowed Edition OS: Windows 8.1
https://linustechtips.com/topic/72040-need-help-choosing-motherboard/
Both of those boards are fine.
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
