Hi I've been saving up and deciding which parts to buy to put in my first ever PC Build. I'm Canadian but going over to the United States to buy it because its so much cheaper  ;) (HAVEN'T bought anything yet)
So far I have narrowed down this:
AMD FX-6300
EVGA Geforce GTX 760 2GB Edition
8GB of ram (1600mhz)
1TB Western Digital Black Hard drive.
700 watt OCZ Powersupply
Windows 7
MSI 970A-G46 AMD 9 Series Motherboard
Cooler Master Elite 430 Mid Tower ATX Case
Asus DRW- 24B1ST 24X Internal DVD Burner
Please note- I have a Samsung 1600x900 monitor
My main goal is:
to reach 60 fps on maxed out settings on Star Wars the Old Republic
My other goals are:
to reach 60 fps on high or ultra settings on Planetside 2
to reach 60 fps on maxed out settings on Guild Wars 2
to reach 60 fps on High- Ultra settings on Battlefield 4
Now to the reason I made this the CPU, I've been wondering what to do about this and here are the options
Either I just buy the AMD FX 6300 Six Core 3.5ghz or I spend the extra $40 and get the AMD FX 8320 Eight Core 3.5ghz? I really dont have the money in my budget  to get an I5 3570K so either one of these cpu's are my destiny lol.
Will getting the AMD FX-8320 with the two extra cores increase my fps? Will increase the performance of my build. Any Suggestions and any help at all about the CPU is greatly appreciated!
Specs:  CPU- AMD FX 8320 @ 3.5Ghz Cooler: Hyper 212 Evo Motherboard: GIGABYTE GA-990FXA-UD3 GPU -EVGA GeForce GTX 970 4GB Superclocked  RAM- 16GB 1600MHz (4x4)  HD- Western Digital Blue Hard Drive 1TB  PSU - Corsair CX 750M Case: Corsair 300R OS-  Windows 7 Home Premium 64 bit Mouse: Razer Deathadder 2013 Keyboard: Razer Blackwidow Ultimate Edition 2013
https://linustechtips.com/topic/72024-first-gaming-pc-build-cpu-help/
I'd go for the Intel, especially if your games rely on per-core. If not, definitely get the 8320.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
You could go 8320 if you want. Are you planning to overclock at all? If you are I would swap that board out for an Asus m5a97 board.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
What buget do you have?
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
I do not plan to overclock. I might in a year or so but not by much.
then stick with the same board and if you want a cpu upgrade go full balls to the walls 8350 cause no point in an 8320.
No, stick with the FX-6300, it's fine. If you're going to spend 40-50 dollars more you better spend them switching that GTX 760 for an R9 280X, you'll get much better performance.I
I'm a Nvidia Fan for Graphics Card I want Physx and Shadowplay (My Geforce Experience) and all the cool things they offer.
Well currently that all comes to $918.15 (includes all the parts and shipping) so the extra $40 will be my mark.
Is the 0.5ghz difference worth an extra  $40 (FX 8320 VS  FX 8350)?
Try to get this ;)
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ Microcenter)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($125.98 @ SuperBiiz)
Video Card:  PowerColor Radeon HD 7970 3GB Video Card  ($259.99 @ Newegg)
Case:  Cooler Master N600 ATX Mid Tower Case  ($49.99 @ Newegg)
Total: $917.90
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-03 15:12 EST-0500)
It's better and it's almost one $1 cheaper :P
Try to get this ;)
Total: $917.90
Can I change that 7970 to a gtx 760? Im a Nvidia gpu fan (GEFORCE EXPERIENCE- Physx and Shadowplay etc.) And is the cpu cooler a screw in one or one of those thermal thingy's?
GTX 760 works better with AMD CPUs but nontheless FX 6300 will bottleneck GTX 760 a bit.
I'd get a cheapest i5 (i5-4430/4440) + H87-G43 motherboard + GTX 660ti or GTX 760 (if you like Nvidia). You will have much higher frames per second.
][ CPU: Phenom II x6 1045t @3,7GHz ][ GPU: GTX 660 2GB ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 8GB @1450Mhz CL9 DDR3 ][ PSU: Chieftec 500AB A ][ Case: SilentiumPC Regnum L50 ][ CPU Cooler: CoolerMaster Hyper 212 Evo & Arctic MX4 ][
Yes, you'll get with about 5fps less in games, but if you want those features.. ;)
and I don't have any clue what  you're trying to say about that cpu cooler
Somebody+call+the+sWAT+team+someone+just
How do you install is it like you have to screw in and plug in or one you have to use thermal paste for?
Can you find me a like $50 dollar case that will have no compatibility issues with the H87-G43 Front USB 3.0 Headers?
Sure, for example:
http://pcpartpicker.com/part/corsair-case-200r
Thanks! Im going to go look at my budget reconfigure some things and see whats happens!
Whats your suggestion for a Power supply? Should I get a 600 watt or 700 watt OCZ Power supply?
If you don't plan to get any SLI/Crossfire anyway, this is a good cheap supply:
http://pcpartpicker.com/part/corsair-power-supply-cx500
If you want to shell out a bit more for a more quality of a supply:
http://pcpartpicker.com/part/ocz-power-supply-oczzt550w
but the same wattage.
You won't need more than 500w power supply if you dont have at least 2 GPUs and you aren't overclocking CPU (you cannot overclock i5 4440).
I don't recommend OCZ powersupplies, Linus's 1000W Gold certified OCZ powersupply was the primary cause for the coil-buzz with the GTX Titan.
A locked Intel i5 will not last you very long and they're unjustifiably more expensive than the FX 6300 or FX 8320.
Get an Asus M5A97 R2.0 motherboard, pair it with an FX 8320, you can run your FX 8320 at FX 8350 speeds without any additional voltage, simply by going into the BIOS and bumping the multiplier.
Well the main problem is I need all the parts to come from one supplier and adding the I5 and the motherboard adds $130 from the previous fx 6300 and gtx 760 etc. I really dont have the extra $130. Whats your opinion on the AMD FX 6300 and fx 8320 in games like SWTOR and Planetside?
The Planetside 2 devs are optimizing for AMD CPUs.
i'll believe it when I see it.
Planetside 2 currently runs like shit on everything but Intel is faster. Their main problem was NOT making this game use multiple threads and they are working on making it more multithreaded... except they've been trying to optimise it since it came out and to no avail.
What's your total budget?
I'd get this if I were you:
CPU:  Intel Core i5-4440 3.1GHz Quad-Core Processor  ($179.99 @ TigerDirect)
Motherboard:  MSI H87-G43 ATX LGA1150 Motherboard  ($98.98 @ OutletPC)
Video Card:  MSI GeForce GTX 770 2GB Video Card  ($329.99 @ Amazon)
Case:  Corsair 200R ATX Mid Tower Case  ($59.99 @ Microcenter)
Power Supply:  Corsair CX 500W 80 PLUS Bronze Certified ATX12V Power Supply  ($59.99 @ Microcenter)
Total: $850.92
(Generated by PCPartPicker 2013-11-03 16:30 EST-0500)
You're golden for High/Ultra settings in 1080p with this setup.
You could get a bit cheaper B85 motherboard if you wanted as well to save 10-20$ but you'd probably lose a few USB ports and stuff.
