Motherboard haunted! Plz Help
Solved by Master Disaster,
1) Its either your KB&M or Ethernet causing your PC to turn on.
To fix go into BIOS and disable any wake on xxx stuff you can find then inside windows open device manager and go into the properties for your keyboard, mouse and NIC (do them one at a time), have a look through and find the "Allow this device to wake my computer" option (sorry can't remember where it is from memory) and uncheck it.
2) First thing I'd recommend is update your BIOS to the latest version, its most likely caused by a bug in your BIOS.
