Headphones with volume control
Well if you can tolerate razer's sound products you can probably tolerate the cloud 2 dongle
so cloud 2's
1 minute ago, Anglogang said:
Thanks for the reply, but I'm looking for strictly headphones with no microphone attached
Budget?
The pair of headphones you want and a cheap inline control. A quick eBay search provides ample options.
look at the suggested gear thread and headfi etc... for suitable headphones to match budget and purpose.
Edit: What's wrong with what you have?
Dirty as fuck, I've tried cleaning them before but with no luck
