So my sister has a MSI Laptop that use steelseries keyboard, I believe it uses the steelseries engine software.  Does anyone know if the software can do the ripple effect from key pressed (when you press a key the color of your keys will ripple out from the pressed key like corsair keyboards)?  I've googled around a bit for her but I haven't seen anything about this topic.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/718699-steelseries-engine-3/
