EDIT: 11/01/17 14:23 This build is finished! I will be posting more pictures and benchmark results soon. Stay tuned!
Greetings, LTT. Thanks for stopping in to check out my build log.
This is what I have been working on for the past month and a half or so. I am building (yet another) sleeper, and it seems like whenever one rolls across here that there are some mixed opinions. Well, here is my shot at it and I don't mind any criticism. I know it isn't all there yet but it's getting really close!
I am working with an eMachines ET1161-07 OEM case, which housed a 2.2 GHz Athlon system some time back, and it never let me down. It sat in my closet for about a year before I decided to pull it apart and sell the parts that I could. From there I put another system in the case, and wound up buying another case to sell that system in.
I was one of those people who swore to AMD on my life and would never turn to Intel. After a long night of thinking and research, I chose to go to the blue side of the coin.
Now that I have a better paying job, my wallet isn't screaming at me as much when I build a system. This is what I am calling Project Z. I know, rather vague, but my goal was to erect the baddest sleeper I could with a $1000 budget. Also, Thanks to Gigabyte for sending me some case badges!
Project: Z
Motherboard: Gigabyte GA-Z170MX-Gaming 5
PSU: Corsair RM650x (Factory recertified)
CPU: Intel CORE i5-6600k @ 4.00 GHz (planning on overclocking some more!)
CPU Cooling: Intel TS13X Liquid Cooling (Single 120mm)
GPU: nVidia GeForce GTX 1070 Founders Edition
RAM: 16GB Corsair Dominator Platinum DDR4-2666
SSD: Intel 600p PCIe 3.0 x 4 M.2 NVMe 128gb
Case fan: 1x Arctic F9 PWM
Case: eMachines ET1161-07 OEM
So now, on to the eye candy for you folks. It's what you came for after all, right? ;) I really like the way this thing is turning out so far, I just have to find a way to get the front I/O cables managed out of the way. Otherwise things are pretty good. I had to run my PCIe power cable to my 1070 over one of my coolant hoses - it would not have worked any other way, but I can always go back and try something else. Let me know what you guys think so far! Any opinions are appreciated. :) I'll be sure to keep you all updated!
uWnr8Bc.jpg?1
COMIC SANS MAKES THE WORLD GO 'ROUND
Lots of power in a tiny package
[Project Z] Gigabyte GA-Z170MX-Gaming 5 | Liquid cooled Intel CORE i5-6600k @ 4.5 GHz | nVidia GeForce GTX 1070 Founders Edition | 16gb Corsair Dominator Platinum DDR4-2666 | Corsair RM650x | DIYPC DIY-F2-O
https://linustechtips.com/topic/718604-updated-sleeper-build-log-project-z/
