So the included LED light which runs along the case, would I need to do anything to power that LED other than connect the 12V SATA cable to a PSU SATA cable? Like is there any molex connection or anything like that, or is it just the 12V SATA cable?
Also, I hear that there is no little power LED front panel connector since the power button LED is the same color as the pre-installed LED strip that runs along the case, is that true?
https://linustechtips.com/topic/717942-enthoo-luxe-led-question/
