9 minutes ago, Core_Tech said:
The question is: why? There's very little in the way of desktop software that benefits from faster memory.
difference between 1600 and for example 2133 or smth is like 1-3 fpsi n game, andm ore stable fps, at least as far as I saw in the latest tests, its not alot but still smth. also I want to know how to do it is it a bad thing to learn smth new ?
https://linustechtips.com/topic/717854-oc-memory-worth-and-how/#findComment-9144756
Just making sure you have a decent reason. It's incredibly time consuming if you don't already have XMP-enabled RAM.
https://linustechtips.com/topic/717854-oc-memory-worth-and-how/#findComment-9144762
That depends on the game. GTA 5 for example you can see minimum fps jumps from 60 to 80. (tested it myself, 1333 vs. 2400 on Haswell)
https://linustechtips.com/topic/717854-oc-memory-worth-and-how/#findComment-9144767
