all fitting should be G1/4 tubing size i'd say 16mm OD or equivalent imperial measurement.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/717824-water-cooling-help/#findComment-9144425
What about fittings. I know one side should be G1/4 but what about the other side that goes into the tube. Should that be the size of the od ?
https://linustechtips.com/topic/717824-water-cooling-help/#findComment-9144439
Use 1/2" ID, 3/4" OD tubing mate.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/717824-water-cooling-help/#findComment-9144468
8 hours ago, Manage My Cables said:
For G1/4 thread what size soft tubing should I be using ? And should all fittings I buy be G1/4 ?
G1/4 is just the size of the part of the fitting that screws into the blocks and rads. You can get whatever size tubes and fittings you want. I personally use 3/8 by 5/8 and this is how they look
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/717824-water-cooling-help/#findComment-9146409
