what is the budget?
CPU:i5-6500 RAM:HyperX Fury 16Gb 2133Mhz MotherBoard:MSI Z-170 M7 SSD:Samsung 500GB GPU:MSI Gaming GTX 980 PSU:Corsair 750i Case;NZXT H440 Razer
Display(s) 3x BenQ RL2755HM 1080p 60Hz 1ms Headset's/Astro A50's/ATH M-50x's Phone:Samsung Galaxy S7/S6 Edge Laptop:Alienware 17 R2 Midrange i7-4710HQ/16GB/970m
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138453
Just now, A7XX said:
gaming mainly, little bit of rendering and using photoshop
so light content creation?
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138461
yes
And only 1080p gaming?
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138470
1 minute ago, Wonton said:
An i5 6600k and 1070. 1070 SLI will be better but thats if your budget will allow
if he wants sli just get a 1080.
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138472
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.99 @ Newegg Marketplace)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($147.98 @ Newegg)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  ($114.88 @ OutletPC)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($124.99 @ Jet)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($619.99 @ B&H)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.49 @ SuperBiiz)  <<enough for two 1080s
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($89.99 @ NCIX US)
Case Fan: be quiet! Pure Wings 2 61.2 CFM  140mm Fan  ($11.49 @ OutletPC)  <<front intake
Monitor: Dell S2716DG 27.0" 2560x1440 144Hz Monitor  ($601.93 @ Amazon)  <<main gaming monitor, GSync/144Hz
Monitor: Asus VZ279H 27.0" 1920x1080 75Hz Monitor  ($159.99 @ Newegg)  <<secondary display, productivity
Total: $2465.97
Generated by PCPartPicker 2017-01-04 07:16 EST-0500
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138540
2 minutes ago, A7XX said:
i already have this stuff! I am looking to update my pc only and this is why i have this budget. Thanks for the help mate
You could get a faster SSD, but it won't make much of a difference... or a bigger CPU cooler, but that won't make much of a difference either.  The more you spend on performance at this point, the less you get in actual performance.
The next step up is the i7 6800K (X99 socket).  Then you will need a bigger cooler to get a higher clock.
https://linustechtips.com/topic/717333-help-for-new-build/#findComment-9138577
