When i went to go start my computer this morning i noticed it was in surround. Usally i would be fine if this happend I could go disable it. But this morning when i started and it went into surround by itself all of the screens were flip floped and if you went into the nvidia control pannel to either disable surround or just changes the screens around it would let you click on the buttons but and move things around just like you should be able to eccept they dont do anything after they're changed. I was thinking of reseting the bios and getting all new drivers because then it would act like it just came out of the box. Any ideas?
https://linustechtips.com/topic/714755-960-stuck-in-surround/
If you can reset drivers and then update them again, that may work.
https://linustechtips.com/topic/714755-960-stuck-in-surround/#findComment-9112690
