When I came back from holiday my wifi started to not work. I could connect but it says "Unidentified Network" and "No internet access"
I did a little research and found out that my ethernet, bluetooth network, Wi-Fi and LAN 3 and 4 medias were disconnected. I checked the cables connected to the router but they were not disconnected or loose.
Another problem is that when I tried to turn off and on my router, no lights were on. The only thing that was on was the power light.
Do you know a solution?
I really need help
https://linustechtips.com/topic/714359-router-problems/
I really need help
try resetting the router
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/714359-router-problems/#findComment-9108096
1 minute ago, LittleWickle said:
I had already done that
What is the router's model number/brand
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/714359-router-problems/#findComment-9108107
I really need help
Are you able to get a connection to the network? If so enter the router's configuration (enter 192.168.0.1 or whatever the address is on the back of your router and try to reset the router to default settings.)
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/714359-router-problems/#findComment-9108238
