Hello to everyone reading this post, so im choosing components for my first pc gaming set up and i was wondering if i would get good gaming performance with these specs:
AMD A8-7670K
MSI Nvidia GTX 1060 3GB Gaming X Edition
8 GB Kingston DDR3 RAM (2 x 4 Sticks)
Gigabyte AMD F2A68HM-DS2H Micro-ATX FM2+ Socket
Corsair 650W  VS Series VS650  80 Plus White
1TB of Hard Drive Storage
So im wondering a couple things: Is the power source fine or did i choose too much? Will i get good performance out of this build?( there is still a possibility to change that 1060 for a 1050Ti, if so, would the performance drop too much?)
I would really appreciate your help! Thanks a lot.
The PC Will be used for Gaming most of the times
https://linustechtips.com/topic/713862-first-gaming-pc-build/
wattage is overkill and the corsair VS is pretty bad. country and budget?
https://linustechtips.com/topic/713862-first-gaming-pc-build/#findComment-9103972
So my budget is around 930 dollar approx, but the thing is that im from chile, so in my country (compared to the usa) the prices are much more expensive
Besides i don't know much about pc building so in the 650W i only took in count the amount of Watts i was getting....
Thanks
https://linustechtips.com/topic/713862-first-gaming-pc-build/#findComment-9103984
The 1050Ti is okay for 1080p gaming.  I'm not sure what the price per FPS is but that's really the metric to follow IMO.  The PSU is one of the most important components in the build and it also is where you can future proof since prices don't fluctuate much with PSUs.  I would recommend going for a 80Plus Gold Corsair, Seasonic, EVGA or Cooler Master.  Try to go for a ~200GB SSD for a boot drive.  Everything looks okay for a budget gamer.
https://linustechtips.com/topic/713862-first-gaming-pc-build/#findComment-9103999
@William.VT- could you please link us a few Chilean websites for PC parts? Also, what is your budget in Chilean Pesos?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/713862-first-gaming-pc-build/#findComment-9104638
Here's a parts list I made for you on pcfactory.cl : a Chilean PC site. There's links for everything. This build features a much better CPU and a slightly better GPU, as well as a much better power supply and motherboard. I'm assuming you have a 1080p monitor, a keyboard and mouse, and a Windows key.
Producto(s) de la Tienda: Internet
Quitar   Productos Cantidad Precio Unitario
Efectivo
SubTotal
1_50.jpg?t=1452718799 ID 13696 WD
Disco Duro PC 1TB Blue
$ 49.990
$49.990
1_50.jpg?t=1471357427 ID 23245 Asus
M/B Intel H110M-D (1151)
$ 55.990
$55.990
1_50.jpg?t=1452892575 ID 20654 Seasonic
Fuente Poder 430W 80+ Bronze
$ 49.990
$49.990
1_50.jpg?t=1452719587 ID 16933 CoolerMaster
Gabinete mATX Elite 344 USB 3.0 Silver s/F
$ 29.990
$29.990
1_50.jpg?t=1464792139 ID 22358 G.Skill
DDR4 8GB 2133MHz Aegis
$ 45.990
$45.990
1_50.jpg?t=1469028542 ID 23099 Zotac
Video NVIDIA GeForce GTX1060 6G GDDR5 AMP
$ 259.990
$259.990
1_50.jpg?t=1467150523 ID 21714 Intel
CPU Core i5-6400 2.7GHz 6MB (1151)
$ 158.190
$158.190
https://linustechtips.com/topic/713862-first-gaming-pc-build/#findComment-9104707
