FL Studios Issues
Go to solution Solved by AC-3,
If no, you could try to drag n' drop the files onto your computer and link to them from within FL Studio. (Screenshot of how below)
I own the Producer Edition and not the Signature Edition, so I don't know if there's a difference in the files on the USB. If you have trouble, just download them from here when you're logged in to your Image-Line account: http://www.image-line.com/content/Samples/Generic+Sample+CD/ (It seems to be that there is less samples in the download than on the USB drive)
I bought the box version of FL Studio Signature Edtion. However, when I reached the final step in the setup booklet ("Install extra samples -  Run the USB installer, select 'Install extra samples' and click 'Next'. Don't re-install FL Studio. FINISHED!"), there was no "Install extra samples" option, even though the USB drive came with over 4000 samples (that I'm unable to use because of the lack of this option).
I've tried searching for the samples in the FL Studios Plugin Browser, but they wouldn't show up. I'm able to use the .wav files as an audio clip, but then it speeds up/slows down the sound depending on the pitch I play it at. The .fst files that were included in the samples folder on the USB installer are unable to be used as audio clips. I would love to be able to use my $400 version of FL Studios to its full potential, so please someone help.
Thanks in advance!
Comic Sans is the best font.
https://linustechtips.com/topic/713709-fl-studios-issues/
https://linustechtips.com/topic/713709-fl-studios-issues/#findComment-9102889
