Advanced calibration guide?
Hey people,
So I just got my first 1440p 144hz monitor and decided to try and calibrate it, I've never done much before just the built in windows tools and adjusting settings on the monitor but this time I'm looking for going one step further, whats the next step before buying calibration tools and whats a decent amature tool that does not cost hundreds of pounds?
Thank you for any help
- LLOYD
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/713636-advanced-calibration-guide/
If you're on nvidia, go to nvidia control panel.
Open this page up and go through the images.
http://www.lagom.nl/lcd-test/?
Focus on, contrast, black level, white saturation and gamma calibration.
What monitor do you have?
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
I am, Thanks I'll give this a go.
Also once you have set it in nvidia control panel. Install this little piece of software. http://goebish.free.fr/cpk/
Open it and press the start button.
Save it, then select lock profile.
This will force the nvidia calibration to be used in your games.#
I always use it myself.
Please help me understand this part.
http://www.lagom.nl/lcd-test/gamma_calibration.php
i have been considering that my monitor's Gamma is a little off, but what?
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
1 minute ago, TAHIRMIA said:
You don't really need to calibrate unless you are doing vital color work
You do on TN panels man.
My System:
My Phone:
My Watch:
Having a monitor set up properly makes a huge difference in gaming, colours can look deeper, dark scenes look better etc.
Suppose it depends on the monitor you have though.
IPS will probably be great out of the box.
Dell S2716DG [TN]
Put the image in the middle of your screen.
Adjust your gamma and try to make the ones on the left labelled 48% blend at the 2.2 mark.
Then go to black level and make sure you can see all the squares, even the darkest one, though it should be hard to see.
Also do it in a dark or very dim room.
Blend with what?
My System:
My Phone:
My Watch:
1 minute ago, BiscuitMassacre said:
Blend with what?
You will see a kinda smooth blending,
This pic is taken from the "what it should look like part"
You see around the 2.2 mark on the left, the red kinda blends in to a smooth blur around the 2.2 mark? That's what you aim for, without ruining the blacks on the black level test.
2 minutes ago, TAHIRMIA said:
Oh, I've always used IPS
Yeah, TN can be pretty bad out the box.
