4 minutes ago, losBaumos said:
If not u shoud try to use an other sata cable on an other sata port on ur mainboard.
I just noticed how stupid this is cause the BIOS should show up even without an harddrive. So is there an possibillity that u have destroyed ur mainboad?
https://linustechtips.com/topic/713519-i-need-help/#findComment-9100364
1 minute ago, JCooper said:
Alright, I was going to buy another hard drive to replace it anyway because I was having issues with it
If it doesn't work with a different cable or port on the mobo, go to a tech support store or download something that tell you the life on your hdd
https://linustechtips.com/topic/713519-i-need-help/#findComment-9100452
