1 minute ago, XRarehunterX said:
Hey I am doing my first GPU overclock with a Gigabte Windforce RX460 OC and i was wondering how do you know when you overclock the memory too far ? Sorry if this is a dumb question .
It will crash or artifact like if the core clocks were pushed beyond the limits.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
so if it runs and there is  no tearing or anything its good even if i have the sliders maxed out, i guess i should have mentioned I'm using the Gigabyte Xtream Gaming engine to overclock my GPU.
1 minute ago, Alexokan said:
Decent. Is power and voltage maxed?
If you find your max on the core, start pushing the memory (ensure that the core OC is stable first).
what I'm using for my overclock doesn't have a power option plus the card i have doesn't have any power connectors its only uses the power from the PCIe slot and that's all
