You have some disk thrashing going on there.  I recommend looking at the task manager to start to find the offender.  I don't know how techie you are but if you want to look into it further, I recommend you look into using Process Monitor to investigate deeper to find the root cause if basic task manager or resource monitor doesn't help out.  This is where you should start before looking at reformatting or upgrading storage otherwise it's possible the problem could come back.
https://linustechtips.com/topic/712872-100-load-always/#findComment-9093995
I agree that more testing needs to be done.  This may simply be the system reindexing the files for faster search function or it may be cashing to the writecashe file.  But it shouldn't affect performance very much on its own.  Did you install any new software before this problem started?
Laws only govern the honest.
https://linustechtips.com/topic/712872-100-load-always/#findComment-9094006
You said that happens after you start your PC.
This seems kinda normal to me. When I had HDD instead of SSD, my disk was at 100% load for like 30sec after it booted up. But after that it was fine.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/712872-100-load-always/#findComment-9094015
Agreed. Does the Disk I/O eventually stabilize.  Also check what startup items are running by clicking on the Startup tab in Task Manager. Take a look at the Startup Impact.
https://linustechtips.com/topic/712872-100-load-always/#findComment-9094023
The problem here is that you have "System" doing most of the thrashing.  Procmon will give you the ability drill down the process tree and see which parent is the culprit. Mark Russinovich has a few videos in "The Case of the Unexplained..." in that he gives a good overview of how to use procmon to troubleshoot these issues. Disclaimer: I work for Microsoft.
https://linustechtips.com/topic/712872-100-load-always/#findComment-9094043
