WiFi Extender with LAN in and out
brightlite
Ok so I've been thinking about this for awhile and I seem to be unable to get this right. So I have a router in another room and have an ethernet cord ran into my room so that I can connect to my computer but the WiFi in my room sucks. Now I know I can plug another router on the ethernet cord in my room, but the last time I had that setup, I ended up having 2 different networks and it was very clumsy disconnecting and connecting each one. So I would like to have is a wireless extender that has a LAN in and a LAN out that I can still connect my computer via ethernet but also extend the WiFi in my room as well. Another reason why I would prefer the extender because how small they are instead of having a large router and having to position it in a odd place so that it can reach the power outlet and my computer. The problem though is that i can't find any extenders like that. If anyone could lend me some info that would awesome, thanks!
hmm, i think the only problem with the router setup you had before was your configuration, if you can be bothered to fiddle around with the settings you might save yourself some money. i dont know much about it but the whole two networks thing sounds to me like you didnt set it up as an access point correctly. look into it, hope i helped a bit aha
Use a switch and then connect the switch to a wirless AP with the WAN function disabled.  Your desktop also plugs into the switch.
Workstation:  14700nonK || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3060 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
