So this is a little odd and i wasn't able to find anything on google, so now im posting here.
First, my System: ASUS Z170-PRO, ZOTAC GTX 980 AMP!, Intel Core i7-6700K with an almost fresh install of Windows 8.1
So it seems like my GPU is locked in its automatic fan control wich keeps it under 60°C at all times.
What i want to do is make the card run more quiet at the cost of running hotter (around 70°C). If i try to set the fan speed (either by applying a curve or setting it manually) it will comply at first, but then return to its automatic fan profile after 10 seconds (See screenshot). I have tried GPU Tweak, Zotac Firestorm, and gave up at MSI Afterburner, all of them had roughly the same effect. i might mention that i had FurMark Running all the time while testing.
I might add, Speeding the fan up also has no effect
Edited by kuki
clarification
https://linustechtips.com/topic/712608-gpu-ignoring-fan-controls/
If you want to use custom fan curve with MSI Afterburner you have to toggle "auto" and "gear icon" next to fan speed.. Both have to be red..
|| i7-4790k | MSI Z87-G45 Gaming | Corsair Vengeance Pro Series 16GB | MSI GTX 970 Gaming 4G | Corsair RM650i 80+ Gold | Corsair 200R ||
so i tested a bit more and it confused me even further: i can put the fan speed to 100% while idle but it will go back down as soon as i launch FurMark. It will reproduceably happen as soon as temperatures pass 40° it will take over, i also tried the same thing with heaven. it seems like some overzealous temperature protection
I have set custom curve for fan speed.. You have to toggle auto and the gear icon(custom fan curve).
1 minute ago, kuki said:
both are red, still not working
In my case it is working, and I am positive that it should work, maybe restart msi afterburner?
this is the wierdest shit, you can see the curve, at this temperature it is supposed to be around 50% but it is at 65% I have both things red, the cogwheel and auto. i have no idea what might be causing that
Edited by kuki
typo
I don't know. In my case it is working..
  • 11 months later...
