Hey guys :)
I have this problem with my computer, when i open gpu-z cpu-z and HWmonitor on the same time, my system crashes/ freeze. I can open anything, not even move the mouse. Im not getting any error messeges. The only way to shut it down is hard power off, or turn the switch  off.
Here is all my specs ( The reason why it said 2x R9 290x is because i have Crossfire
Specs:   https://gyazo.com/e96b7255a05e3ca259f177b6c5b85758
NOTE!: i have windows 10 home NOT windows 8.1
If you need more info, then just post it in the comment :)
Any suggestions? :)
Thanks for the help! - Gombel :)
Merry christmas and happy new year :)
https://linustechtips.com/topic/712240-system-freeze-3/
Could you replicate this issue, but with sound playing? Because that only happens to me when my drivers decide to crap themselves, and the sound it's outputting when that happens is a continuous tone.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/712240-system-freeze-3/#findComment-9088357
When it happens my youtube sound keeps playing in about 5-6 secends and then it stops..
Yes sure, ill also try without sound when im home. If it works, how to fix it then? :3
Thanks for replying :)
https://linustechtips.com/topic/712240-system-freeze-3/#findComment-9088375
Well, try using DDU (Display Driver Uninstaller) to uninstall and reinstall video drivers.
USEFUL LINKS:
https://linustechtips.com/topic/712240-system-freeze-3/#findComment-9088464
