Ok i've gotten an old DELL LGA 775 computer, it's the optiplex 780 and i got a gtx 1050ti into put into it but i haven't got the 1050ti yet and i'm not sure if the pci 16x slot is right or if the card might be too tall. It's running an intel Q8200 using intergrated graphics, gonna do the 771 -775 convention on an E5450 Xeon. People, please fix.
https://linustechtips.com/topic/712190-help-me-please/
Any PCIe 16X slot will work fine with a 1050Ti
even an 8X slot will work if it's PCIe Gen2
I haven't checked, but 99% chance it fits
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/712190-help-me-please/#findComment-9087900
