When building a brand new PC from scratch can I validate everything works (putting together the PC outside of the case and turning it on) including the CPU without putting on the CPU cooler. The PC will only be on for a couple seconds to make sure all the components work.
https://linustechtips.com/topic/712094-booting-up-pc-without-cpu-cooler/
It's risky, although I think it can be done for a few seconds. I'd use the stock cooler though just to be safe if it came with one.
Current system: CPU:I5 6600k 4.5Ghz, CPU Cooler: Asetek 550LC, Motherboard: Asus Z170 Pro Gamer, Ram:Adata XPG 4x2 2400, Graphics Card:MSi GTX 970 + Zotac 970, Hard drives:256gb SSD+1tb WD Blue, Case:Corsair Spec 01 Power Supply:XFX TS  750 watt Bronze, OS:Windows 10 64bit
TERRIBLE TERRIBLE IDEA.  aNYTHING GETS INTO THE CHIP SOCKET Boom fried mobo and cpu (whoops sorry for caps lock) but do not do that
yeah, you can do it
I did it once to get into the BIOS and didn't have issues
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
If it's only for a couple of seconds (No more than 5) than it's is probably ok, but still be cautious.
I'd put the stock cooler on just to be safe. My friend tried doing it without the cooler for an old Xeon and it got really hot really quickly, even though he only POSTed it.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
