On my quest for a quiet computer, I've been able to find and replace most of the noise in my computer. My main issue at this point is the fan on my power supply. I'm currently running an EVGA Supernova 750 B2, which is a high quality power supply, but is the only noise I can really hear in my case.
Are their any reasonably priced power supplies that are known to be quiet? Downsizing would be okay, but I'd like to keep it modular if possible.
Specs:
  • i5 4590
  • RX 470
  • 2 x 4 GB, may upgrade to 4 x 4
  • Hyper 212 EVO
  • 2 120MM Fans
  • 2 Hard Drives + SSD
  • 2 Optical Drives (I could take the DVD drive out)
https://linustechtips.com/topic/711867-quiet-power-supplies/
Are their any reasonably priced power supplies that are known to be quiet? My PC specs should be in my signature.
You don't have a signature.
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/711867-quiet-power-supplies/#findComment-9085026
You need more ram and that psu is just fine. Maybe you could look for a be quiet psu though.
https://linustechtips.com/topic/711867-quiet-power-supplies/#findComment-9085033
What fans are the 120mm ones?
For true silence you'd want to minimize HDD usage by using it for things like photo storage, video storage and programs that don't run in the background.
You could maybe do with getting a quieter fan on the 212 Evo.
As for the PSU, SeaSonic and EVGA both have silent PSUs
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/711867-quiet-power-supplies/#findComment-9085107
I don't necessarily need silent, I'd just like one that isn't very loud. The silent ones I've seen have been significantly more expensive.
https://linustechtips.com/topic/711867-quiet-power-supplies/#findComment-9085196
