the difference is pretty self explanatory, replacement cables you replace straight at the PSU, assuming you have at least a semi modular power supply, extension cables simply extend the existing ones.
not all psu's have replacement kits so knowing your model would help. Getting extensions is the cheaper option and best if you have room in the case for the extra length.
https://linustechtips.com/topic/711802-need-cables-modding-help/#findComment-9084404
