2 minutes ago, zer0676 said:
ok how would i have to download it again
I already told you, You quoted it:
5 minutes ago, TheNuzziNuzz said:
You can install them in Radeon Crimson software. Enter the settings, then click updates in the bottom left, then check for updates, and install the driver.
Computers r fun
https://linustechtips.com/topic/711534-problem/#findComment-9082099
4 minutes ago, zer0676 said:
Um what now
Do I need to quote myself again?
Sorry. It says "Drivers Up to Date" Which means the correct drivers are already installed...meaning you didn't uninstall the. A simple google search will answer this question better than I will here.
2 minutes ago, TheNuzziNuzz said:
Computers r fun
https://linustechtips.com/topic/711534-problem/#findComment-9082136
WHAT I just uninstall the diver
https://linustechtips.com/topic/711534-problem/#findComment-9082177
