yes, but even with the best magnetic filters you will get some dust in the case
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
13 minutes ago, abdo601 said:
yes but will there be a big difference between the magnetic and this?
a big difference? No
with a good filter you will see finer dust inside the case, almost powder like.
with other filters you will see larger particles but nothing too big.
