Troubleshooting Ethernet with built PC
Solved by Silent_arrow,
i had the4 same problem.you need to install the motherboard drivers. Usually the motherboard comes with a cd or usb that the drivers are on if you have that run it and install the drivers if not on a different computer download the drivers from their website download them and transfer them to some kind of media you can plug into your new motherboard(CD or USB) then run them and that should solve your problem.
