39 minutes ago, metrocsgo said:
Hey i'm looking to make a small lan pc that can fit in full size/normal gpu's and all the stuff a pc needs but i'm not sure rather I should chose a micro itx or mini itx or whatever? Thanks in advance
if you dont want to upgrade the system at all, then a mini itx cube case is probably the best bet.
