BIOS is Stuck
Go to solution Solved by Electronics Wizardy,
Try taking out the bios batttery, should reset the bios.
Alright, I'm kind of freaking out at this point.I had my pc running, but I was having trouble installing my linux os, so I asked around for some help. Well someone told me to go into bios and turn anything legacy to the opposite. So I did and that was uefi. Well, whatever the check that did, it screwed me over royally. I can't get into my bios settings now at all. The shortcut is delete or F2, but neither are working. It's amost as of I'm not pressing anything at all. I triedpressing the reset button, but that shut the pc down and turned it back on. I see the AS Rock page, and the shortcuts I could use, but nothing works and after like 45 seconds it gives me a black screen with a blinking white underscore. My specs are as follows:
 Two Xeon Oct score Hyper Threaded 2.6 Ghz CUPs
GTX 770 Classified
ASRock Rack EP2C602
8 GB Adata RAM
Any help is appreciated. Thanks in advance
https://linustechtips.com/topic/710081-bios-is-stuck/
