hello i just bought a msi 1060 gaming x 6 g . i have a very old system basically i just wanted a good gpu. https://pcpartpicker.com/list/NLrcgL
i installed the card got the latest drivers and installed it but i dont seem to have any performance . when i try to open cs go or dota 2 on steam a black screen just poops up and goes down  then nothing , when i try to run ac or cod bo 3 it says dx 11 not found . in nfs rivals it says this card does not suppot  . please help i dont know what to do .
the gpu dosent show on hardware monotor or cpu z but it shows on system info
when tryin to play dota 2 it says unable to find direct 3d device check that your graphics driver is working properly and that you satisfy the mini specs of the game
i will be much obliged thank you
https://linustechtips.com/topic/709979-gpu-problems/
Do you have UEFI? You may have to switch to Legacy in BIOS, so your old system will recognise the new hardware.
Aside from that, I don't know what PC you have, but from my own early experiences: My first PC was a pre-built HP, and it just would not accept a new GPU when I tried.
Are you sure you've fully pushed the card into the PCI slot?
https://linustechtips.com/topic/709979-gpu-problems/#findComment-9064513
