So after building a new pc and installing windows I started getting this error, I tested the ram using memtest86+ and everything seems fine. Any help would be greatly appreciate it
Crash Dump:
https://drive.google.com/open?id=0ByDZ_NzPrBrLNk9GWmdye...
"Winter is coming"
    -Ned Stark
https://linustechtips.com/topic/709753-weird-error-irql_not_less_or_equal/
I've had this error once and it was due to a bad firmware flash on a mouse of all things. Check anything that could be using a driver as they could be bad. Remove GPU and extra expansion cards, and use different peripherals (if available)
idk
That's usually a bad driver on some component on the computer. Start reinstalling drivers especially for stuff like network adapters, be them integrated or NICs
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
is there anyway to pin point which drivers are the issue? maybe its in the crash dump?
"Winter is coming"
    -Ned Stark
