I'm doing a new build using the Define R4 and I have some questions.
1. I'm using a SeaSonic X-850 PSU, will I have enough room to mount a 140mm intake fan on the bottom fan mount?
2. I need some good fans, a nice mix of silence and performance. I know Noctuas are good fans but just a little too expensive. Out the list whats a good fan, if it's not on the list then tell whats a better fan.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345069
http://www.newegg.com/Product/Product.aspx?Item=N82E16835426041
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553007
http://www.cougar-world.com/products/fans/cfd_black_hb_fan.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181028
3. Should I buy PWM fans or 3 pin?
4. Should I use the built in fan controller on the R4 or use the fan headers on my Motherboard (ASUS Z87 Hero)?
Thanks
https://linustechtips.com/topic/70972-fan-questions/
3 vs 4 pin is down to your usage scenario. My case has a built in fan controller, so I would elect to use 3 pins. Attaching right to the motherboard, it's probably best to take 4 pins.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/70972-fan-questions/#findComment-972855
Any of those fans are a good choice, I would use the built in fan controller since it's really handy and it just a quick flip of the switch. I would get 3 pin fan headers for the ones that you're going to be using as intakes and exhaust.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/70972-fan-questions/#findComment-972869
