Help with screen protector
Go to solution Solved by GamerDude,
When I first got my V20, I had a run-of-the-mill SP installed, this was a cheap SP that didn't quite fit the V20 screen well because of the curvature of the screen. Look at the pic below, note the lack of seal at just midway on the LG brand and logo below, same on just above the shortcut icons on top, and the sides as well. Bought a UAG Plasma case while I was at it.
I went to another shop, this time, a shop that specializes in cases, SP's and accessories for phones. The shop owner recommended that I use a 'premium grade' (whatever that means) tempered glass and fingerprint resistant SP that was made for the V20. It goes without saying that I took it and this is what it looks like....note that it is smaller than the actual scree itself to avoid the curvature. I also got a VRSDesign Crystal case while I was at the shop. Loved the design, but the earphone hole on it is a tad small, the UAG case allows for somewhat bigger IEM jacks/plugs.
I guess you'll have to look for an SP that would fit or that was designed for the G5......there should be a good selection to choose from since the G5 is a popular phone.
5 hours ago, AndreLebrao said:
What is the best screen protector for the lg g5? Ive already used 3 and all of them werent very functional :/
By " weren't very functional", what do you mean?
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
They all filled up with air bubbles and i had to remove them, got them all instaled by shopkeepers so it wasnt instalation mistake. Could you recommend the best glass one?
What? Air bibbles? Are you using those plastic film SP? I'm using a more premium fingerprint resistant tempered glass SP on my V20 and it's great (just don't ask me the brand as the guy I'd gotten it from simply asked me if I'd wanted a better SP for it). I also have typical tempered glass SP on both my other phones (Xperia Z5 Premium and LG G Pro 2) and I've not experienced any issue with air bubble. Didcha install the SP yourself?
Nope, i got it installed on a shop, but the curvature on the top of the phone doesnt let me instal a full sp so it always gets off, i am going trough one per 2 months
