I've been using bitfenix fans, the silentwings 3 from be quiet are awesome, EK Vardars are very quiet too... never used Arctic cooling fans
Ive also used NZXT fans, quiet at low rpm, coolermaster are quiet at low rpm too, but they arent moving as much air... the Corsair SP fans are noisy as hell...
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
https://linustechtips.com/topic/707668-fans-for-raidators120mm/#findComment-9039594
Arctic F12's are about as alright of an option as it gets and are usually at a reasonable price.
That being said, there are usually many viable alternatives that may be as good if not better.
What are you looking for in your fans?
https://linustechtips.com/topic/707668-fans-for-raidators120mm/#findComment-9039894
