I going to buy the pc that I've selected, please help me check whether this is a good build or not, if not please use pcpartpicker to tell me. Thank you.
https://pcpartpicker.com/list/DsDQKZ
Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/
Planned Build PcPartPicker
https://linustechtips.com/topic/707461-pc-build-help-needed/
For a first time builder it was very nicely put out
I would not change anything.
But
  • Different GPU as do you think red would stand out too much from the rest of the build
  • 212 Evo is fine. Though there could be better coolers like Noctua or Cryorig (not C7) and Dark Rock which coole component better when overclocked
  • PSU is a nice choice. You can up to EVGA GQ/G2 if you want to as it is better quality but CXM is not bad
  • You don't need Windows PRO. Unless you plan on something else. Home will be fine
  • I wait for audio enthusiasts and pro to come but not sure of Kraken
  • No mouse?
https://linustechtips.com/topic/707461-pc-build-help-needed/#findComment-9037176
But
  • No mouse?
I personally think (as a noob builder) the fan is nice already, I know that a Noctua is a great fan, but i would just stay with the one I've chosen, I don't mind it standing out since the build is probably going to face the wall, I already have a Razer Deathadder Chroma mouse, and any suggestion of windows for gaming and light work?
Please tell me which PSU is better in your opinion.
Thx
https://linustechtips.com/topic/707461-pc-build-help-needed/#findComment-9037209
Thx
try the EVGA B2 750W, allows you to SLI in thr future, very good quality and only $40 after rebates($60 without).
https://linustechtips.com/topic/707461-pc-build-help-needed/#findComment-9037249
what i'd go with:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($230.98 @ Newegg)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg Marketplace)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($122.88 @ OutletPC)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.97 @ Jet)
Storage: Crucial MX300 275GB M.2-2280 Solid State Drive  ($72.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Best Buy)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING Video Card  ($399.99 @ B&H)
Case: Phanteks Enthoo Pro M Acrylic ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ B&H)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.58 @ OutletPC)
Monitor: Dell S2417DG 23.8" 2560x1440 165Hz Monitor  ($450.27 @ Amazon)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard  ($124.99 @ Best Buy)
Headphones: Razer KRAKEN 7.1 CHROMA 7.1 Channel  Headset  ($69.99 @ B&H)
Total: $1855.60
Generated by PCPartPicker 2016-12-16 00:51 EST-0500
https://linustechtips.com/topic/707461-pc-build-help-needed/#findComment-9037285
