So I have a micro sd card, and it would be nice if I could have it connect to my phone via lightning, unfortunately, the one for lightning cost $50 compared to the android one which is $13.. So I was thinking, what if I connected my lightning to usb cable, then connected a sd card reader. Would it work? Also what if I bought something like this, then connected the Leef micro usb to sd card reader, would it work?
Thanks!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/707318-lightning-usb-sd/
Thanks!
The port stated are for charging and syncing with PC. I am not sure if peripherals such as card reader would work.
https://linustechtips.com/topic/707318-lightning-usb-sd/#findComment-9035478
Darn.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/707318-lightning-usb-sd/#findComment-9035492
I've found some lightning-USB dongles that work for attaching USB flash drives, but you'll have to do the research on your own to see if it will work how you plan to.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/707318-lightning-usb-sd/#findComment-9035513
I got something like this guy here -
http://www.bestbuy.com/site/pny-duo-link-on-the-go-usb-lightning-flash-drive/4846500.p?skuId=4846500
Works like a charm.  Just plugging a USB into the end of a lighting-USB cable didn't work for me.  The iphone doesn't have a driver built in for it, or something like that.  The app that goes with the duo link is free, just the USB cost anything.
https://linustechtips.com/topic/707318-lightning-usb-sd/#findComment-9035661
