2 minutes ago, Howitz said:
what are the pros and cons of both, and which one would you go with in order to provide wifi capability to your desktop.
From what I have seen (not extensive testing by any means) is that the PCIe ones will provide slightly better performance, due to generally having a better antenna setup, and forgoing the extra lag introduced by USB.
YMMV though.
Cons of pcie are that you will have to have a free pcie port.
When in doubt, re-format.
It's hard to run a PCI-E wireless adaptor if you have more than 2 cards because all of your PCI-E lanes will be taken.
Otherwise PCI-E adaptors generally are faster and more robust than USB adaptors.
I had an account called Joegeddon active since April 20th 2015
Desktop
AMD Ryzen 5 2600 | XFX RADEON RX580 8GB XXX | 16GB 3000MHz DDR4 | Thermaltake Versa H22 | Corsair RM550x PSU | MSI AM4 B450M-A PRO Motherboard
1TB 7200RPM HDD | 500GB 7200RPM HDD | 500GB M.2 WD BLUE SSD
Laptop - Asus UX303UA
Intel i7 6500U | Intel 530 Graphics | 12GB 1600MHz DDR3 | 256GB SATA 3 SSD
PCI-E lanes can be shared with ease.  Not sure why people keep making such a big deal out of this.  You can even get PCI-E expander cards, like the RB14eu, which allow for 4 PCI-E WiFi cards in a single physical 1X PCI-E slot.
Didn't know that was a thing.
Desktop
Yup, toss 4 miniPCI-E radios in one of these (or even 4G radios if you want, along with a SIM card and USB port attachments if needed for the 4G), and you're good to go:
Looks like it uses a PLX chip.
alright guys i got this one from amazon.ca in cad dollars, i dont think it will have issues on an asus z170a right, also i will be gaming, i have no issues gaming on my old lenovo y510p laptop wifi, ill be damned if i cant on this pcie adapter...
https://www.amazon.ca/gp/product/B016K0896K/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
