Wireless headphone recomdations?
Hello. I am looking for some headphones that run over Bluetooth but I can also plug in if they are out of juice or using a non Bluetooth device. I would like some that are biased towards music listening that perefereably have a nice bassy sound.
Any recomdaions on some? I'm a bit of an audio newbie also in case you haven't noticed.
I saw the video. Are there any like those except without active noise canceling?
https://linustechtips.com/topic/707181-wireless-headphone-recomdations/
Just now, ImperialSteele said:
Linus just did a review on two of the higher end, noise canceling options.
Yeah I saw that and I don't really care that much about noise canceling headphones. Are they're any like those just without the active noise canceling?
There are probably tons of lower quality headphones that have bluetooth, but cost almost as much, and if I remember correctly from that video, Noise Canceling can be turned off on both headphones. What's your budget?
Better dead than Red.
Pheonix
CPU: i5 2500k @ 4.6ghz Mobo: Asrock Z77 Extreme4 RAM: G.Skill 16gb of DDR3 @ 1600mhz GPU: Gigabyte GeForce GTX 1060 6gb Extreme Gaming PSU: EVGA 700B Storage: 480GB SP SSD and a 960GB Ultra II Sandisk. Cooler: Cryorig H7 Case: Phanteks P400.
Do you think that headphones that are he same as those just without Nc ones would cost more or less he same?
They would be decently close in price, within like 70 dollars or so. The new Beats solo Bluetooth headphones are a prime example.
Pheonix
