Audio setup - ideas?
Hello all
Having a little question. I'm looking for a solution to connect the following:
Razer Tiamat 7.1 headset
Desk speakers - like the wharfedale diamond 220
and a bluetooth headset if possible to my computer.
The issue is that i would like I to be like 1 click to switch between them. It would be even better if each program could be controlled to use a specific audio device (and afterwards easily changed).
Do you guys have any ideas? :)
/Out
Zortoxon
https://linustechtips.com/topic/707110-audio-setup-ideas/
Are the I/O just standard headphone jacks?
I had an account called Joegeddon active since April 20th 2015
Desktop
AMD Ryzen 5 2600 | XFX RADEON RX580 8GB XXX | 16GB 3000MHz DDR4 | Thermaltake Versa H22 | Corsair RM550x PSU | MSI AM4 B450M-A PRO Motherboard
1TB 7200RPM HDD | 500GB 7200RPM HDD | 500GB M.2 WD BLUE SSD
Laptop - Asus UX303UA
Intel i7 6500U | Intel 530 Graphics | 12GB 1600MHz DDR3 | 256GB SATA 3 SSD
https://linustechtips.com/topic/707110-audio-setup-ideas/#findComment-9032772
