should work fine. but why are you getting an fx 8300 and rx 460? not worth it.
https://linustechtips.com/topic/707034-will-it-work/#findComment-9031818
6 minutes ago, LawOfGames said:
Will this still work? Just asking. becuz of this note.
  • Some AMD 970 chipset motherboards may need a BIOS update prior to using Vishera CPUs.
https://pcpartpicker.com/list/YkZXVY
I would not buy the old fx cpus right now
Wait for zen, but if you need it now, go for an i5
https://linustechtips.com/topic/707034-will-it-work/#findComment-9031819
making a budget pc
https://linustechtips.com/topic/707034-will-it-work/#findComment-9031831
5 minutes ago, LawOfGames said:
making a budget pc
if you're making a budget pc, use an i3 or x4 845 if your budget is really tight instead. you also shouldn't be spending so much on a motherboard, heatsink and on an overpriced graphics card. what's your budget?
https://linustechtips.com/topic/707034-will-it-work/#findComment-9031846
